Teh Snorkler
Re: Teh Snorkler
"Teh Snorkler" ?
Is this some sort of male enhancement machine?
Asking for a friend...
Re: Teh Snorkler
Naw, I just harvested all the parts from the previous pre-amp build, cleaned the board and started the layout.harddriver wrote: ↑Tue Nov 29, 2022 2:03 am Did you drill and stake a new turret layout specifically for the Snork build?
I've had to drill a couple of new holes so far, but it's going well.
Since I'm only using two 12AX7's I should have plenty of room. Trying to be as efficient as possible though.
Re: Teh Snorkler
I sent you 3 Evox/RIfa's if I remember correctly? No? They should all be in this build! IMHO for the WIMA Boggy sound!
How did you extend the Evox/RIfa leads?
NICE........................Board's looking good!
Can't wait to hear this thing and whole lotta AIC riffs!
Re: Teh Snorkler
Yes. The.68µF caps were the only components I am able to use in this circuit.harddriver wrote: ↑Tue Nov 29, 2022 5:16 pm I sent you 3 Evox/RIfa's if I remember correctly? No? They should all be in this build! IMHO for the WIMA Boggy sound!![]()
NICE........................Board's looking good!Your lead dress is looking very neat and orderly!
Can't wait to hear this thing and whole lotta AIC riffs!![]()
The Wima caps will be delivered later this week.
If I'm not happy with the tone, I will try rolling different 12AX7 tubes in/out, then perhaps try swapping out some caps.
I just used bits of leads that I had trimmed off other components.. Bent a little hook into one end, crimped onto the leads of the box cap using a very small pair of needle-nose pliers and then applied a drop of hot solder.
- Ritchie's Party Hat
- Has thanked: 310 times
- Been thanked: 292 times
Re: Teh Snorkler
Right. This is for Nuno-tone, right?
Users browsing this forum: No registered users and 35 guests
