Ceriatone AH-50 Build
Re: Ceriatone AH-50 Build
Looks great PLX! You will not regret installing the depth mod and NFB mod controls, both will make the amp super versatile!
Yeah, I think so.harddriver wrote: ↑Tue Jun 07, 2022 10:14 pm Looks great PLX! You will not regret installing the depth mod and NFB mod controls, both will make the amp super versatile!![]()
I drilled an extra hole on the faceplate, right next to the Presence control and placed the Variable NFB control there..
I used the hole on the back of the chassis where the Effects Loop Return Level knob was supposed to go for the Resonance Control knob.
Final sanding with 320 grit sandpaper.
Chassis mounting bolt holes drilled, pre-stain conditioner, 'natural' stain, 1 coat clear polyurethane & copper shielding tape applied.
If you have the room next to your depth pot you might want to put your NFB control there on the front. That is one control you might fiddle with quite a bit. The depth you kind of set it an leave it. I had my NFB control right next to the presence control on my Zilla 4 gain stager and I would tweak that thing all the time, it was hoot, 27K it's a plexi....100K it's a Super lead ...200K it tight like a Splawn.
Headbox looks good, I figured you would Snake print tolex that bad boy but you went for the Boogie look huh.
PLX you need to go fuzzy carpet covering a la 80's Randall.
That's it right there. The knob with no label.harddriver wrote: ↑Fri Jun 10, 2022 4:51 am If you have the room next to your depth pot you might want to put your NFB control there on the front. That is one control you might fiddle with quite a bit. The depth you kind of set it an leave it. I had my NFB control right next to the presence control on my Zilla 4 gain stager and I would tweak that thing all the time, it was hoot, 27K it's a plexi....100K it's a Super lead ...200K it tight like a Splawn.
Reggie asked me if I was gonna cover it with tolex.
When I said I was just going to stain it, he said, "Ok then I'll make the front panel out of Baltic birch with a nice grain."
Honestly, if I hadn't found a cabinet builder at the last minute who would fucking listen to me and pay attention to the dimensions of the chassis, I was about to go down to Home Despot and buy some damned birch plywood and "hillbilly" the cabinet together myself.
I know it has everything plus the kitchen sink in there, but did you incorporate the "nitro secret pedal" into the circuit too?
Asking for a friend...
