Teh Snorkler
Re: Teh Snorkler
I believe that mystery capacitor gives extra... "enhancement".
Re: Teh Snorkler
I have the Wima® caps now, so depending on how this sounds I may change out some of these to enhance the tone.
Re: Teh Snorkler
PLX wrote: Fri Dec 02, 2022 4:47 pm
harddriver wrote: Fri Dec 02, 2022 4:06 am You have 48 hours to tell me what the hell that capacitor is doing...............No more No less................. :lol:
It is a high-pass filter. Including the upstream stuff (Zo of the preceding stage and the 1M to ground), the -3dB point is ~1.3 kHz.
One 48 hour deadline and you deliver! Way to go PLX! ;) :D
Re: Teh Snorkler
harddriver wrote: Sat Dec 03, 2022 2:31 am One 48 hour deadline and you deliver! Way to go PLX! ;) :D
I just asked over at TehAmpGarage.
They had a message for you about your question..
Re: Teh Snorkler
lll wrote: Fri Dec 02, 2022 8:50 pm I believe that mystery capacitor gives extra... "enhancement".
Why YES....YES it does!
Reminds me of and old joke.....
A young indian brave sits down with his father the tribe elder and asks "Father how do you know what to name your children of the tribe?"
The Father says " Well my son when I awake the day of child's birth the first thing the great Spirit allows me to see is what the Great Spirit in the sky wishes the new creation of life to be called by............
"Why do you ask Two Dogs Fucking?"
Re: Teh Snorkler
PLX wrote: Sat Dec 03, 2022 2:37 am
Message for me????????? Schucks.......................
Re: Teh Snorkler
LOUDthud wrote: Sat Dec 03, 2022 12:58 am Just to deepen your understanding, .001uF = 1nF = 1000pF. You may need to do these conversions accurately to use the calculators mentioned.
The roll-off mentioned is not too far removed from one at the input to the third stage of the TW Express.
Re: Teh Snorkler
I use this hand dandy calculator to figure out the shelving frequencies when I'm trying to determine bypass frequencies.
http://www.muzique.com/schem/filter.htm
Re: Teh Snorkler
harddriver wrote: Sat Dec 03, 2022 4:04 am I use this hand dandy calculator to figure out the shelving frequencies when I'm trying to determine bypass frequencies.
I use all of the online calc apps too.
He was being snarky because you said 100pF instead of 1000pF
I didn't even carefully read that part because it was ancillary to the question.
Re: Teh Snorkler
PLX wrote: Sat Dec 03, 2022 5:11 am
Yeah.......so I fat fingered the last 0 in 1000pf so sue me........... :lol: :lol: Sheesh............ :roll:
I've seen that layout orientation(which is on the Muzique calculator page) of high pass low pass filtering before for pedal circuits I've just usually always seen people using the plate snubber cap or the .001uf or other value caps going to ground off of the coupling caps off of V1A or V1B in a Jose mod ala Cameron but I guess if it works in pedals that specific layout can work in amps as well, I just not seen it used really until the Snork, he didn't use it int he Ecstasy if that schematic is correct.
Thank goodness he was able to put me in my place about a typo though I will forever be grateful........ :oops: :D :roll:
When I was digging into my notes looking for that elevated heater info I came across my schematic of the Bogner Ecstasy OD channel which I loosely used to base my 4 gain stage amp around as well as the SLO and Splawn. If you want the schematic to compare to the Snorkler I'll send it. It might be interesting to look at how he went from Snork to Ecstasy design wise.
Users browsing this forum: Baidu [Spider] and 1 guest
