RAT Pedal Clone Build
Re: RAT Pedal Clone Build
lll wrote: Fri Aug 26, 2022 11:00 pm Yes.
Thought you were running into a reactive load...
It should be silent on the amp/cab side and you monitor your tone through your DAW's speakers (at any volume).
I change the signal chain around. Always tryna find a better recorded tone.
After I rebuilt that amp I wanted to hear it thru the speaker cab to make sure what I was hearing, rather than thru the reactive load into the DAW.
The amp is stable now, so this setup will probably be my "go to" rig until I finish the BE-50 clone.
Users browsing this forum: No registered users and 25 guests
