The shape is based on the GJ2 concorde that Grover Jackson was making a few years ago. The top is 2 pieces of 15mm ASH and the body wood is Fiji Kauriharddriver wrote: ↑Sat Sep 18, 2021 2:42 pm It reminds me of the Jackson Rhoades model. Looks great! is the entire body one piece ash or did you have to laminate as a two or three piece body?
you and me both bro.. I just turned 50 and love them more now than ever
it is similar. I wish now I had filmed myself doing the process, because a few have asked else where how I did it. The finish is call Ceruse. Instead of using a blow torch you use a wire wheel on a drill and rip up the grain lines, then sand the entire thing and repeat a couple of times. the sanding helps smooth out the bits you want to be black (generally black is the best base colour because it shows up the other colour better)
