Temple Audio Design Pedalboards
Looking at building a new pedalboard with one of these.
Anybody use this stuff before ?
Re: Temple Audio Design Pedalboards
Is that the board you have to use zip ties to hold your pedals?
RockyStar wrote: Tue Sep 21, 2021 5:37 pm Is that the board you have to use zip ties to hold your pedals?
I guess you could, but they want you to use this..
Ahh...I see. Looks like a cool setup in that case.
There have been some boards I have seen where people zip tie their pedals to the board. Wasn't sure if this was the company or not. I cringe at people zip tying their pedals. I guess the for sale blurb could read "lovingly applied zip ties" instead of "velcro lovingly and professionally applied."
I don't like their method tho'
It requires you to stick that metal plate on the bottom of your pedals with an adhesive pad. :?
I was thinking of just using longer screws for the bottom plate of the pedals, and put them thru the underside of the pedalboard, into the effect pedal. That would hold the bottom pate on the pedal, as well as secure the pedal to the board. :idea:
