So, I Did My Own Video Analysis..
..of the Malaria Carey injection video. :|
I see more than what was discussed in the previous video. When the person walks in between the camera and the subject, the needle gets withdrawn back up into the syringe.
Then, you see it extend back out before the fake injection.
I found a pretty good copy of the original video and enlarged it and slowed it down to 1/4 speed.
Re: So, I Did My Own Video Analysis..
It' hard to see is there a needle present? She obviously didn't get the vaxxx... :roll:
harddriver wrote: Tue Sep 28, 2021 3:08 am It' hard to see is there a needle present?
Yep.
It's there when the syringe first comes into frame, then it disappears back into the syringe.
After the person walks between the camera and the subject, you can see the needle extend out.
Also, watch that stainless steel cylinder right inside the tip of the syringe.. it appears and disappears when the needle is extended or retracted.
I see that it retracted into the syringe. That doesn't happen on a real syringe does it? :roll: :roll:
harddriver wrote: Tue Sep 28, 2021 3:21 am I see that it retracted into the syringe. That doesn't happen on a real syringe does it? :roll: :roll:
Those are movie props.
Being used by someone who is not adept at their use and function, thereby revealing the fakery.
