Pigtronix Echolution 3
I just picked up one of these for kicks. Small footprint stereo delay with some great usable features.
Pigtronix is proud to announce the launch of Echolution 3. Following the success of its sought-after predecessors, Echolution and Echolution 2, the all-new Echolution 3 offers a streamlined user interface, remarkably hi-fidelity audio, and more selective sound design options than ever before.
Echolution 3 is a multi-tap stereo modulation delay offering a myriad of sound design options including reverse, jump, pong, modulation tempo sync, variable low pass filter, flexible signal routing and comprehensive MIDI control. Delay times ranging from 100ms to 5 seconds can be dialed in using the Time knob or via Tap Tempo using the left footswitch. A second delay tap can be set to the same length or a fraction of the main delay time to create rhythmic echoes. The ¾ fraction creates a dotted eight note delay, while the Golden fraction uses the sacred geometry of the Golden Ratio (.382) as the multiplier for the second tap. The multi-tap settings can be even further enhanced by the stereo ping pong effect, which causes the different delay taps to switch sides on each repeat. Store up to 4 presets, unlock hidden features with the Universal Remote footswitch, and design yet unheard delay lines. Runs on standard 9VDC.
https://www.pigtronix.com/uploads/pigtr ... Manual.pdf
Re: Pigtronix Echolution 3
Spent more time with this wonderful pedal today and I absolutely love it. Does a lot of the things you typically want a delay pedal to do with simplicity and excellence. It isn't as deep as a big box Strymon but it sounds amazing and does what it does well. If you are looking for a delay pedal, you would be wise to check this one out.
