Ireland is 91% Vaccinated and Covid cases are soaring…
Re: Ireland is 91% Vaccinated and Covid cases are soaring…
I truly wonder if the vax percentages are accurate. I'm getting the sense that it's 50% at best, based on how they keep pushing it. They only needed 60% vaxxed, then it went to 70%, then 75%. Then you have countries claiming over 80%, but it's not enough.
Well...Well...Well...
Obviously the anti jab folks are the problem and not the death jab itself. The clot shot is so good for you that they are incentivizing it in order to con you into taking it.
Wake up people!
The Jab is the problem.
End of Story!
DO NOT TAKE THE SHOT!!!
Wake up people!
End of Story!
Agreed! I sense that numbers are getting spun all over the place in all kinds of ways.CoolGuitarGear wrote: ↑Fri Oct 29, 2021 4:23 pm I truly wonder if the vax percentages are accurate. I'm getting the sense that it's 50% at best, based on how they keep pushing it. They only needed 60% vaxxed, then it went to 70%, then 75%. Then you have countries claiming over 80%, but it's not enough.
