Modern attenuators
Findthetone1
Modern attenuators
Post by Findthetone1 »
There is ceratinly a great choice of attenuators these days and I read about people raving at how good they are. Are they really that much better that what was available 10-15 years ago? I have a Weber Mass Lite that is around 10 years old or so and haven't used it in forever. I bought to tame the monsterous River K-Tre I had and I hated it. Could've been user error but I felt like it put a blanket on the tone.
Re: Modern attenuators
I have an old THD hotplate and a Rivera Rockcrusher. The Rivera is very wellbuilt it's overbuilt actually but any setting attenuating more that -8DB it starts to affect the tone just the same as the THD. I only use either to make playing my 68 plexi and 72 Superlead tolerable while shaving some volume off, if I use -12DB or more on the either I notice the tone seems to be more affected like less punch and diminished highs but again that's how our ears perceive it so I don't think there is a way around it even if technically the overall sound is 100% identical but just more quiet. So I think the Flecther Munson curves/effect still applies even to modern attenuators even though we would not like it to be the case.
I think one might be better off slaving into a Suhr Reactive load then reamping with a another power amp like a Matrix for lower volume playing. As long as you understand something attenuated -12 to -20 Db just isn't going to have the same audible dynamics because of the Flecther Munson effects.
Findthetone1
That’s kind of what I was thinking. Great info. Thanks brother!
The modern variants do well.
Fryette Power Station
Boss Tube Amp Expander
Suhr Reactive Load
Semantics here, but the Suhr Reactive Load isn't an attenuator, but a load box.
Some attenuators attenuate and serve as a load box as well (Hot Plate).
I'm not a fan of any attenuators unless I'm just shaving a few dBs off... any more than that, and the tone literally gets compressed (squashed) and loses dynamics.
AFA loadboxes, there is a big tonal difference between reactive (Suhr Reactive Load) and resistive (THD HotPlate).
lll wrote: Sat Jan 15, 2022 1:37 am Semantics here, but the Suhr Reactive Load isn't an attenuator, but a load box.
Ok Smarty Pants...
