DIY RFI Filter
DIY RFI Filter
Used Bud® box with random holes: free
Radio Shack 100 microhenry, 1kHz RF choke: $2.58
Ceramic disc 1uF capacitors: 8 cents
Switchcraft jacks: $6.24
Getting rid of the fucking noise from my pedal board: priceless :D
Re: DIY RFI Filter
How's the distortion?
Did you use a germanium or silicon choke?
True bypass, right?
Re: DIY RFI Filter
lll wrote: Thu Jun 16, 2022 10:51 pm How's the distortion?
True bypass, right?
The unique problem I have is; I live on a hillside with a broadcast antenna sitting directly on top of the hill behind my house.
So, even though I have taken every possible step to scrub the RF from my home recording studio, when I run a hi-gain signal chain I get radio frequency interference coming through my amps.
This works by forming an pi filter (inductor-capacitor) network in the guitar signal path.
Re: DIY RFI Filter
what about a rudimentary faraday cage around your studio? is that easily done?
Re: DIY RFI Filter
lll wrote: Fri Jun 17, 2022 12:26 am what about a rudimentary faraday cage around your studio? is that easily done?
You're going to think I'm joking, but I used a product called "SolarBoard" to skin the walls in our home offices/studios. It's under the drywall.
It's radiant barrier material, and it's in the ceilings and the walls.. :|
The walls and rafters were then filled with spray foam insulation.
Re: DIY RFI Filter
No tap tempo?
