Same as before... these are all Greenbacks. Zero FX except tape satch, limiter (no EQing). Vote!
Charvel So Cal w old JBJ
Friedman BE-OD Deluxe
'66 Fender Deluxe
Suhr RL
DAW
All iRs use a single SM57
BoGreen:
BritStraight:
G12M Greenback:
Rand NB412:
Suhr 4x12:
Which iR Sounds Best 2?
Re: Which iR Sounds Best 2?
The Suhr 4x12 sounds more scooped - more like the actual track.
Ratt - In Your Direction
Listening on laptop speakers after a very long day I chose the BoGreen. It was close between a couple of them. The others, not as much. What I find difficult in these comparisons is having to remember/compare/contrast something you are hearing now against something you heard a minute or 5 earlier. It would be better to have a very condensed clip of a few seconds each switching back and forth in cases where a standout choice isn't obvious. YMMV
