Floyd Rose - FROFTB 37
This gear forum will not be held responsible nor liable for any transactions that occur
Authentic Floyd Rose® Fat Brass Tremolo Block
37mm tall
Solid Bell Brass
This "Fat" brass big block will add mass and sustain to your Floyd Rose bridge along with the tonal qualities of brass.
Brass has been a much desired material for guitar luthiers dating back to the invention of the instrument; it is notorious for increasing warmth and clarity simultaneously, a rare combination. While greatly strengthening chord clarity and beefing up individual tones, it also greatly improves resonance, especially in the midrange of the instrument. All of these improvements are accompanied with the undeniably vintage sound and feel of this time-tested material.
Since this block is larger than a conventional sustain block, it can also limit upward travel of the tremolo and can be set to rest against the body in a blocked bridge configuration. For floating bridge setup this block may require some routing in the spring cavity.
$24.00 shipped
(will ship to CONUS only)
