same clip as my old, just revisted.
Rest In Peace Solo (remix)
Re: Rest In Peace Solo (remix)
That has everything right about NUNO tone that I hear.......nice clank, crunch, bite in the highs, yet a bit of compression on the closed and bent notes.
That's how my Rat sound into my amps! That MP1 sounds killer lll! I have always been curious about those things since they were all the rage!
I just bought myself a Musicaman HD130 for my continued Ed exploration. I'll be doing a write up when I get my 6CA7's installed and biased this week hopefully then I will give it another spin.
I also have to install new filter caps into my 67 badmaster then I will do a head to head with the Muscman!
You have tickled my ear to the MP-1 though lll.............
This clip has got that slight, mid-frequency phase shift thing going, and the "clank" in the upper mids.
Damn good job
Damn good job
This is a remix of the exact clip I did here:
viewtopic.php?f=27&t=5100
(i've since taken down the old clips)
Gear is:
Charvel So Cal (OFR) with old JBJ-labeled JB from 80s
Pro Co RAT 2 (new)
ADA MP-1
Two Notes Torpedo CAB M+ using Big Hairy Guitars (Michael Nielsen) Alien White Cab (SM57,R121) which is iR of Steve Vai's old cab from DLR days with V30s
DAW magic
Gear is:
Pro Co RAT 2 (new)
ADA MP-1
DAW magic
What were the RAT dial settingslll wrote: ↑Mon Aug 22, 2022 11:35 pm This is a remix of the exact clip I did here:
Gear is:
Pro Co RAT 2 (new)
ADA MP-1
DAW magic![]()
Dist: just a hair upPLX wrote: ↑Mon Aug 22, 2022 11:52 pmWhat were the RAT dial settingslll wrote: ↑Mon Aug 22, 2022 11:35 pm This is a remix of the exact clip I did here:
Gear is:
Pro Co RAT 2 (new)
ADA MP-1
DAW magic![]()
Filter: 12 o clock
Level: 2 o clock
using the RAT as a "JustALittleMorePusherizer" (which also adds the killer natural RAT eqing to the tone).
Set like that, you're essentially using the RAT as a clean boost.
Also getting that phase shift thing going on with the FILTER control at 50%
