Gonna mess with this setup like this dude has... only 2 (two) stompboxes... but it's a full rig (2 channel; Fender clean & Marshall JCM800) including 2x mics
And For My Next Trick (AMT M2 + Two Notes CAB M)
Re: And For My Next Trick (AMT M2 + Two Notes CAB M)
So.. it's an amp sim + cab & mic sim in a pedal
edit: Ok, I went and looked at the specs. They say you have to run your amp into this device and then run a pass-thru cable to a speaker cabinet.
There's two pedals with this "trick":
1) AMT M2
2) Two Notes Torpedo CAB M+
The AMT M2 is basically a Marshall JCM800 in a stompbox format. You could literally plug your guitar into it and run it out to the PA and have full on raging Marshall tone live.
Here's Brett Kingman doing a demo:
The Two Notes Torpedo CAB M+ does numerous things (all of which can be turned on or off independently):
- clean preamp emulator
- poweramp emulator (different t00bs)
- Two Notes "DyniR" loader (movable mics x2)
- iR loader (for your own iRs)
- EQ section
- "Nicerizer" section (thump, etc)
- Reverb (short reverbs like room, etc)
I've ran my ADA MP-1 straight into it (see last Nuno clip Rest In Peace). I've ran a line out signal from my Plexi (loaded down with Suhr RL) straight into it. etc - and then to my DAW.
It's hard to call it "anything" specific because it does so much.
Here's Michael Nielsen showing it:
So the idea here is (signal chain):
guitar
AMT M2
DAW
It could also be an extremely portable live setup:
guitar
AMT M2
EHX .44 Magnum (stompbox sized power amp) or similar
1x12 speaker cab
I could also stick a pedal in front of the AMT M2 for boost, like so:
guitar
Catalinbread Naga Viper
AMT M2
DAW
1) AMT M2
- EQ section
guitar
AMT M2
DAW
guitar
AMT M2
1x12 speaker cab
guitar
AMT M2
DAW
Steve Stevens is running Cab M's on this leg of the tour and not using cabs at all.
