Friedman BE-OD / Dirty Shirley Pedal Clone Build
The BE-OD and the "Dirty Shirley" are almost identical pedals - both designed to emulate high-gain amp designs.
Both are referred to as "amp in a box" pedal types. The BE-OD in particular earns for itself the designation "BSIAB" or brown-sound-in-a-box.
I own the Friedman BE-OD and it's hands down the best overdrive/distortion pedal I've ever played.
The BE-OD is missing a midrange control, but the Dirty Shirley has a midrange pot. The BE-OD has a "tight" control pot, whereas the Dirty Shirley only has an on/off toggle for the tight control, used to tighten up the bottom end.
The concept of this built is to combine the two pedals into a single stomp-box enclosure with all the controls of both.
drilling template, center punched for pilot holes:
drilled enclosure:
This guy does a real good side-by-side demo of both pedals.
Re: Friedman BE-OD / Dirty Shirley Pedal Clone Build
Dude you are on fire with builds lately........... :shock: :lol:
harddriver wrote: Sat Aug 07, 2021 8:18 pm Dude you are on fire with builds lately........... :shock: :lol:
Rustoleum Hammertone Brown - 5 coats:
Waterslide decal for control knob labels. 2 coats clear gloss:
Project schematic :
components:
PLX wrote: Sat Aug 07, 2021 1:56 am The BE-OD and the "Dirty Shirley" are almost identical pedals - both designed to emulate high-gain amp designs.
If my FM3 didn't match incredibly well, I would have kept that pedal... nothing else sounds like it (BE-OD Deluxe).
Users browsing this forum: No registered users and 42 guests
