FYLT tone test
FYLT tone test
Re: FYLT tone test
This may be as close as I'm evar gonna get to that tone. :D
reference:
Re: FYLT tone test
I think It sounds damn good, brother!!!
Re: FYLT tone test
Re: FYLT tone test
PLX wrote: Thu Sep 08, 2022 5:22 pm
Shit, that sounds good, too!
Re: FYLT tone test
Watson503 wrote: Thu Sep 08, 2022 7:30 pm Shit, that sounds good, too!
Thanks man !
There was so much EQ done to Ed's tone in the studio to get it to where it sound like what you hear on the record, it's incredible.
Re: FYLT tone test
General overall EQ is similar, however when you crank on the first A chord (during verse) there's a nasty tone in the upper-mids... sounds like too much clipping at those frequencies or something.
Re: FYLT tone test
lll wrote: Thu Sep 08, 2022 10:12 pm General overall EQ is similar, however when you crank on the first A chord (during verse) there's a nasty tone in the upper-mids... sounds like too much clipping at those frequencies or something.
I thought I was the only one hearing this...It almost sounds like the guitar tone is out of phase somehow. When he hits the open chords it sounds like a phase effect enveloping the core guitar tone that's not there in the actual isolated ED clip that PLX posted as a comparison.
Maybe there is a layering issue with that EQ matching software? I don't know enough about the EQ software to comment further. It you listen hard it does sound like a phase 90 is on the entire clip. If you listen to the Ed isolated clip it's warmer with definition.
Re: FYLT tone test
I hear that too. There's a thing that happens with fab filter because it's making EQ adjustments in real time.
I keep dialing out Fab Filter to where it's was only in the mix at about 15%, because of that phenomena.
I've pretty much emulated what FF was doing with the EQ that's native to Reaper.
Here it is rendered without the Fab Filter EQ:
Re: FYLT tone test
PLX wrote: Thu Sep 08, 2022 10:47 pm I hear that too. There's a thing that happens with fab filter because it's making EQ adjustments in real time.
That harshness in the upper mids is still there, but just a hair less from previous.
Ears tell me it's roughly 1.5 or 2KHz area.
