The RAT Effect
The RAT Effect
Did this clip with ADA MP-1, RAT & Two Notes CABM.
Only used CABM interface for EQ/tweaking.
100% Dry tone in DAW (limiter only).
The trick here is it's doubled and panned 100% L&R - the left channel is RAT off and the right channel is RAT on (set to slight boost effect).
So you can pan L or R to hear the difference.
It tightens the low end and adds a little hi mids.
Again, RAT on right side only
