VH 1 tone test
VH 1 tone test
Re: VH 1 tone test
Very close. A little more EQ tweaking 8-)
Re: VH 1 tone test
JB pickup > Univox UD-50 volume pedal > Nembrini Plexi amp sim (Presence 10, Bass 1, Middle 10, Treble 10, Vol I 7, bright input) > Celestion G12 20-watt > SM57 "bright" blended with SM57 "dark" Blend Mix: (Dark mic at -14 dB, Bright mic at -12 Db)
Neve 1073 Mic pre-amp:
Guitar tracks then bussed into :
NLS Channel Strip
Pultec EQ
API 550
Eventide H-910 Harmonizer (7% mix)
UD-50:
Volume: 4 o'clock
Gain: 7 o'clock
Tone: 8 o'clock
Re: VH 1 tone test
Be curious if you did another run exactly the same except use Super 70 pickup.
Re: VH 1 tone test
Re: VH 1 tone test
PLX wrote: Sat Jan 27, 2024 5:13 pm new one :!:
https://soundclick.com/share.cfm?id=14720112
Link no longer available.
Re: VH 1 tone test
lll wrote: Sat Jan 27, 2024 10:20 pmLink no longer available.
Sorry. I finished the track and took the old ones down.
https://soundclick.com/share.cfm?id=14720235
Re: VH 1 tone test
PLX wrote: Sun Jan 28, 2024 1:38 am
Sounds a hair more grungy/crunky than the original (and your last clip)... like there's a slight constipation in the low mids (pushing a little too much gain in those freqs). The last clip's distortion was nice and clear with the right grind (secret pedal) to it, but the EQ needed work.
EQ is slightly better; still a little too much mids.
Is the Jalen pickup again? Can't get away from those JB (Jalen) mids; can't EQ them out.
For this tune I got surprising (to me) results with SH-55 Seth Lover (PAF) and the secret pedal into my Plexi. I was like, "PAF? no shit?!?":
Re: VH 1 tone test
Damn. That's good :!:
Re: VH 1 tone test
lll wrote: Sun Jan 28, 2024 2:03 am Is the Jalen pickup again? Can't get away from those JB (Jalen) mids; can't EQ them out.
No shit, man ! I think you're right about that. I was getting sooo damn close to that tone while A/B'ing the isolated guitar track in the DAW, but it was like every time I'd start tweaking the EQ I could only get so close.
I tell ya what, using room mics in the blend seems to help !
