Queensryche - Anarchy X
Post your own audio performances here
Remixed... again. Cuz that's what life is all about. Might do the tack on Revolution Calling later.
Re: Queensryche - Anarchy X
What are you using for bass ?
PLX wrote: Mon Jan 29, 2024 4:50 am What are you using for bass ?
AmpleBass Lite w Pultec EQ - on top of a MIDI track
lll wrote: Mon Jan 29, 2024 4:53 am AmpleBass Lite w Pultec EQ - on top of a MIDI track
I'm demo'ing a drum plugin right now.. SSD Drums.
PLX wrote: Mon Jan 29, 2024 5:05 am
Quick trick with getting killer drums:
Have a track for your drums, then bus that to a 2nd track for "squashed drums" (parallel, or sometimes called "New York" compression).
On the "squashed drums" track, slap a compressor (1176, or even better, a dbx 160 - which is *the* drums comp) on it and squash the fuck out of it.
Then blend in the "squashed drums" track to taste. This will give you the *punch*.
