Hercules Guitar Wall Hangers
Anyone ever seen one of these just break.. like, for no reason ?
I have a Fender bass I use for recording. Had it hanging on the wall with my other guitars for years. All using the exact same Hercules wall hangers.
I noticed the other day the metal sleeve that comes out of the wooden block that is lag-bolted into the wall has just cracked. There's a bolt inside the sleeve that kept the bass from crashing to the floor (thankfully), but WTF ?
I contacted Hercules support, but no response. Thinking about just replacing them all with another brand.
Re: Hercules Guitar Wall Hangers
That is very odd. I have never seen that but that could end up being a very bad deal if it fully broke. I had a similar bizarre issue with a different product. My Snark Tuners have turned from that rubberized type finish to a sticky, tacky finish. As I went to use it the pivot just crumbled and the read out portion just completely disconnected from the clamping portion.
These products need to be made better for sure. Sorry you had that happen. Good thing you noticed it and it didn't drop the instrument and cause any damage or break a headstock, etc.
RockyStar wrote: Sun May 15, 2022 12:45 pm That is very odd. I have never seen that but that could end up being a very bad deal if it fully broke. I had a similar bizarre issue with a different product. My Snark Tuners have turned from that rubberized type finish to a sticky, tacky finish. As I went to use it the pivot just crumbled and the read out portion just completely disconnected from the clamping portion.
Found this thread where several people have experienced the exact same thing. Fucking hell !
https://www.thegearpage.net/board/index ... s.2323005/
Damn, man...! Glad your bass is all right and didn't fall!
Watson503 wrote: Sun May 15, 2022 3:35 pmDamn, man...! Glad your bass is all right and didn't fall!
Thanks man !
I just ordered a different brand hanger this morning.
I put in a support ticket with Hercules on Wednesday, still no response.
